Is this a lost cause? (Exhaust Tip Question Again)
JDMMA70
2,550
Houston
I use over 3 different polishers and cleaners and i still cant remove the stains and tarnish. Is there any products out there that can help remove it. Its starting to look nasty and its only 2 1/2 months old.
Im currently about to try Blue magic Metal Polish, but is there any way i can remove this.
Thanks
~JDMMA70
JDMMA70
2,550
Houston
Its stainless I know that's why it turned gold but still I heard those stains could be removed
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
i have the exact same cat-back,however,mine isn<t like that since i<ve always washed it when i wash the car. it does that over time and with heat. i really don<t think there is much you can do, unfortunatly
jdub
Feb 10, 2006
10,730
Valley of the Sun
I think he's talking about the "splotchy" effect...heat will turn stainless a gold color.
You might want to try a product specifically for stainless...or, give rubbing compound a try.
I use Blue Magic metal polish.
OneJArpus
2,798
try CLR! hehe, try turtle waxes cleaning compound. I had the same issue with my exhaust but i sold it. They cleaned it up rather well so there is something out there i just dont know what they used to clean it up.
Cheap grade SS isn't actually rust resistant so "stains"
An easy test is try a magnet if it sticks it's got a lot of mild steel in the mix, you can sand/polish it but without some clear coat it'll return.
JDMMA70
2,550
Houston
The magnet did not stick at all. Im going to try Yoshimura Stain Magic next. Since this happens on motorcycle exhaust pipes as well.
yes, pop into a motorcycle shop and pick up their products...
some of the best polishes and protectants can be found there...
MKIIINA
Destroyer of Turbos
Plano, TX
SupraMaster;1010546 said:
Mother's is the shit for everything. They have some of the most amazing products on the market. Once you go Mother's, you'll never go back to anything else.
Dylan JZ;1010636 said:
++1. the hks super dragger for my IS was stained when I got it and I went at it with a Dremel and Mother's metal polish and its back to new!
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
TRUE! try it out.tase tryed it at my dads job and there was all kind of nasty stuff on this sink and it cleaned it right off
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
any abrasive metal polish should get that thing clean. It will be oxidized by heat again though, so after polishing, get it as clean as you can (rub down with methanol/acetone/etc) or else any residual polishing compound will result in uneven coloring/spotting
