due to my intercooler, i had to move my radiator overflow into the engine bay, taking up some of the battery space. To prevent having to relocate the battery, a guy at a shop suggested the braille battery, its like 11lbs. So, eventually I got the car running, but still had alot of electrical issues that i was working on. I've changed all the grounds except for the trans mount ground due to current issues. I know some discharge of the battery is normal, but if I leave the car more than 3-4 days without starting it, the battery drops to like 5V. I thought maybe there was a drain somewhere, but now I'm wondering if maybe the battery just isn't up to handling the task. Aside from the stock electrical components, i'm running a turbo timer, S-AFR, a boost controller, UEGO, boost gauge, a head unit and an amp. When the car is running, the voltage is right around 14V, 13.8 if the headlights and foglights are on. Any ideas? comments? I'm trying to find the next size up in the braille line just in case
