IHI-RHC7 said:Yes, ACIS is more like a secondary intake runner length and doesn't add any top end power, but increases runner length for more low end torque on the GE. The only way to control the ACIS system is with a factory GE TCCS.
If you are using GE electronics, stick with the GE manifold, it may help spool up, If you are on GTE electronics, stick with a GTE mani or look up Ron Ramirez or Sethron for a custom front facing design.
nissota said:My problem with a FFIM is that I need AC and PS. I live in Jamaica. It is kind of warm here.
My impression was that FFIM required you to lose the AC and put the alternator in its place.
I will look up ACIS. Thanks
chris89 said:to keep the valve open is easy.... Just disconnect the single vaccum hose going to the thing... then its stuck open, you'll notice that there is almost no low end and you'll see the same gains at high rpm.+
It is loaded so it is normally open. You need vaccum applied to close it.I am sure I can find a way to keep the valve in the open position at all times.
IHI-RHC7 said:The only way to control the ACIS system is with a factory GE TCCS.
Shawndude said:Just use the turbo manifold. It's a good unit, and lot less complicated than the N/A one. Most FF proponents really are just after the looks, and try to sugar coat it why they want one, but the stock manifold is the least of your worries on these cars.
Bishop92t said:Actually the ACIS system is purely mechanical. The ECU has nothing to do with it, however I doubt the calculations for the ACIS design work for the turbo.
Bishop92t said:30-40hp gain on what though? If you're trying to shove 30psi with a monster turbo through the stock manifold then yeah you'll definitely see improvement with a FFM. It just depends on what your bottleneck is.
nissota said:My manifold has the valve in the normally closed position without any vacuum.
If I connect vacuum hose to the diaphram actuator then the throttle plate will open.
When the engine is under boost (no vacuum to the diaphram) it will then close.
I modified my manifold as Tubbie recommended .
I removed the diaphram actuator and locked the throttle valve in the open position.
