what are the advantages or disadvantages to the swap. I know the gears are diff but are they stronger built and if i am going to do a gte swap on my ge would it be worth it since I have it out already?
Poodles;1731367 said:Which one do you think is stronger![]()
alucardunit1;1731329 said:i am hopping for 400-600 just some where about there. i know its a wide range but i am going to rebuild a gte then throw it in so it sounds like it would just be the better choice since i have to replace the clutch in the process.
Poodles;1731950 said:Only evidence I need is the simple fact that Toyota didn't feel the W58 was up to the task to hold the extra torque of the 7M-GTE.
RazoE;1732063 said:but they also thought the stock torque of the headbolts was enough to hold down the massive power of the 7M and look what happened there...................
