I haven't found a good search result answering my question. i want to buy a koyo, keep it in th 7mn for a bit then take it off and stick it onto the jz. if not, then ill just temp seal it.
The koyo has mounting brackets for the jz hydrofan setup but from what ive heard the 7m will work with the koyo with little or no modification to the fan setup.
