is the AFM damage? HELP!
Status
Not open for further replies.
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Well now has a BIG problem, I send my car to replace the freeze plug, so today they finish but when they go and test the car, beings the problems.
The mechanic told me, when the finish all engine wiring connection, and star the engine at idle, the engine was excellent, but then they go for a road test before call me.
SO they went to some AMPM to buy few think and the mechanic said, let see how this run under pressure, so test the car in an open straight street, so when they shift up to 2nd gear, he hear an explosion and a black smoke begin to go out from the tail pipe!.
So the mechanic call me explain to my the situation, I told him to check the fuel pressure, and was at 50psi at idle oH sh!T:icon_cry: ,
I go immediately to the workshop and check all vacuums lines and everything was fine, we reduce the fuel pressure to 38psi, but the black smoke continue coming out, the mechanic remove the AFM connector with the engine running and have no deferens:aigo: .
Right now is too late to check voltage and make some test:cry: .
So what do you thing ?
is the AFM damage?
Could be damage because a over mega rich condition?
Really I don’t believed, because I have a wide band O2 meter, how the mechanic didn’t check the fuel pressure before a road test?
AAAAAAAAHHHHHHHHHHHHHHHH!!!!!, This sucks!:1zhelp:
90T04
Tucson, AZ
www.azsupras.com
Dude i understand there is a language barrier here but this stuff cracks me up. Im was ROFLing when I read it. It sounds like Ali G's character "Borat" is typing this. :biglaugh:
Anyway, to be some help, I would check your engine codes. Is the check engine light on? See if you have a code 24 in there which is for a AFM.
Hope this helps
Ryan
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hope this helps
Ryan
Sounds like he used www.freetranslation.com. I'm serious. My spanish teacher yelled at me for using that site for my spanish homework. The sentences were all broken and shotty.
-Steve
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Hi guys, why so rude!:3d_frown: , I need help and you told me only grammar observation!, c’mon this is serious, well at least for me.
The check engine light is not on, and I don’t have the time to check it.
So the short question is?, If some have this kind of problem? If yes Help me!:1zhelp:
90T04
Tucson, AZ
www.azsupras.com
You cant hurt the AFM from running a extremely rich condition. Even though you dont have a code, the AFM can still be bad, and just sending out a frequecy that is to high for the air that is coming in. You said you heard an explosion, was it more of a pop that sounds like you popped off an IC pipe coupler? Check over your IC piping and make sure you have no leaks.
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
I vote that one of the clamps or whatever you had on the ic pipes came loose, it happend to me on the freeway....was not fun...buch of black smoke and poor acceleration
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
boost fiend said:
what kind of mechanic dont know about a turbo engine and know to double check all the ic pipes?
kinda sounds fishy to me!
some old mechanic, with a mullet. probably only knows a bout huge displacement, distributers, and carburators.
Status
