our 7mgte smokes on start up after it sits for a while... and if you let it idle for a bit and then hit the gas it'll smoke. Is that the turbo or valve seals? Car has 90K miles and a bone stock hair dryer, I mean turbo.
Bad valve guide seals. Nothing major, unless you start fouling plugs. Check their condition.Supra5MGTE said:our 7mgte smokes on start up after it sits for a while... .
Worn out turbo bearings behave this way. Putting your cats back on may help, if you're willing to give up the power.Supra5MGTE said:and if you let it idle for a bit and then hit the gas it'll smoke. .
Red Dragon said:I don't get any smoke, but my engine bay smells like burnt oil all the time. I think the turbo burns a little oil, as occasionally a very small whiff of oil smoke will rise up near the turbo. Doesn't seem to be very bad, but the car does smell like burnt oil a lot.....
On another note, it a turbo "blows" does this mean I could lose all oil pressure in a heartbeat and toast my engine? I've never had one blow on me so I don't know. If so, I guess I need to pull the turbo and have it rebuilt.
pull the turbo? bah thats for wussies, your supposed to drive it till it dont drive no' mo'!Red Dragon said:I don't get any smoke, but my engine bay smells like burnt oil all the time. I think the turbo burns a little oil, as occasionally a very small whiff of oil smoke will rise up near the turbo. Doesn't seem to be very bad, but the car does smell like burnt oil a lot.....
