Is it possible to start 1jz on 7mgte map sensor?
808steeze
28
Hawaii
Like the title states I was wandering if I could just get my car started and maybe move it around with the 7mgte map sensor as I do not have a 1jz map sensor yet.
Thanks for any replies.
and yes I know it will not fit the 1jz plug but I was going to dremel the ridge off If need be.
I believe you're talking about the boost sensor that is used for the boost gauge.
Honestly, I have no clue if it would work...
808steeze
28
Hawaii
That's the sensor, it says "sensor assy. Turbo Pressure".
Does anyone know if you can use this to start up and move the 1jz not for wide open throttle.
Thanks.
