In the faq section in the 1jz section it says that common parts between the 2jz and 1jz are the plugs. Spark plugs for 1jz -ngk 3330 and 6097. A little search and you can find almost anything on this site my friend.
It should work out ok i put 2j plugs in mines also, and works just fine but I dont recall what kind i just went and bought plug for a 2j and tried it and it worked so yeah it works.
those plug's will be fine.if you start running higher boost,go with a colder plug (ngk6097)and smaller gap.people run the denso ik22 also,but not really worth the extra $$
