I have a walbro and an afpr setup which has been fine for 3 years.
A couple of times in the last week, I have tried to start my car and it turns over nicely but doesn't hit a lick. I get a ride and when I come home I check for codes, nada.. Try it again and it starts up fine and runs fine. Couple of days later same deal, spins nicely doesn't fire. check codes, all clear. look at fuel pressure with key on and nada, even after spinning it over. I should have about 40psi if the pump is working. After checking codes, it starts again. I am thinking the fuel pump is not kicking in, but when it runs and I have driven it some it works fine for the rest of the day.
The other issue I am having(related to this?) is that when I boost i get a fuel cut like cutoff, but no CEL codes. I put a wideband on it and when I hit the cut off, the a/f goes through the roof(20 or so). I am afraid to boost at all now. Is this my walbro giving it up and not making enough pressure to squirt appropriately?
Any other theories?
Any other theories?
