Is it me or is my car lazy
T
turbo06
Guest
Ok so I hop into the bitch and the car runs realy good for a while and at stops it idles at 1k rpm's but after driving for a while it will idle at about 500 rpm's. When I accelerate it sorta feels like it wants too go but won't till after a few seconds. I noticed that if I just let it roll on its own then give it gas it takes off fine. Oh uh its an 87 automatic turbo and the tranny slips alittle getting out of the low gear or 1st if you will, into 2nd gear.
89Turbo
804
Portland
find the vaccum leak, or start by replacing all of your old shitty lines with silicone lines, did my whole motor today and gained 2lbs(or whatever vacuum is measured in) of vaccum at idle, apparently i had a leak :dunno:
T
turbo06
Guest
You know what......I think you guys are right, I'm gunna get that super blue hose kit from suprasport.com and go from there. Muchas gracias:x:
