Is anybody Using Dual Layer Dvd-r's(DVD9'S)
Fuzz420
Are U Here 2 take My Baby
Ive been on a HD binge, its ok to burn regular dvd's to dvd5's, but hd definelty degrades on this size disk, so i believe its time to upgrade to some new media.
For anybody using these disk, how is reliability.How many disc have u burned before you have a bad disk that error's out.
Another issue i have is price. The norm seems about $2 a disc compared to about $.50 to $.80 per disc. Where did you get your media at and how much did it cost you. Right now ive priced 25 disc for $59.99 locally at circuit city.
iwannadie
981
gilbert, az
Try supermediastore.com for disks, so far they are Way cheaper for any media Ive bought.
Ive only used a double layer dvd once lol, cant say anything about them.
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
Yup use them alot.
Haven't ran in to alot of bad DL media.
60$ for 25 you are overpaying.
I usually get it from staples on sale.
Fuzz420
Piratetip;913505 said:
Yup use them alot.
hmmm, never thought about that. Honestly i didnt think they would put them on sale.
What speeds disc do you buy, if you even care to pick a speed?Whats the actual disc space usage size. Like the dvd5's say 4.7 gigs but you can only uses 4.5gigs
Piratetip
1,179
69
MKE, WI
Yeah they are on sale sometimes. Or clearance.
I try to burn media at 2X so I could care less about speed, I am for best quality burns I can get.
Capacity is 8.5GB and it is possible to use all of it if you know how.
Kai
That Limey Bastard
HD doesn't 'degrade' on a disc.
I use Verbatim DL's and they're 100% fine. They're more scratch resistant than most, and the disc has a quality feel to it.
The only tradeoff is the 2.4x burn speed, but if you're burning large clumps of data i wouldnt want to burn faster than 4x anyway.
Fuzz420
if HD doesnt degrade i was very disapointed in the way the 720p looked on the tv. When i get some dual layer disc ill try a 1080p copy of the same movies so i can judge for myself. Would the dvd player itself be a limiting factor?
Kai
That Limey Bastard
The bitrate doesnt just change when you put it on a disc, the copy on the disc, is the same as the copy on your hard drive.
If your TV is 1080p and the copy is 720p, you're upscaling, so it might look a bit pants.
iwannadie
981
gilbert, az
Uhm, you cant burn Hd movies on a dual layer and play it on a standard dvd player and expect 1080p...? Or, am I missing something here. The standard dvd player will play just that, Standard def.
Fuzz420
Kai;914143 said:
This man is correct...unless of course, Fuzz is taking the HD source and re-encoding them for DVD - in which case the point of quality is entirely obvious :)
doh:nono:
Ok then so its the dvd player itself. The dvd player is hooked up via rca jacks. Ill switch them over to component jacks and that should be the difference :)and yes kai i am re-encoding them to play specifically on the dvd player. This "720p" dvd-r disk is still far superior to a standard dvd
