is a stock flywheel new fine for around 400hp?
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
i'm doing a decent performance build and with an upgrade clutch, i was wondering if i could get a new stock r154 flywheel or do i have to get an aftermarket lightened one?
thanks, t3d
supra8903
512
Latham, NY
yes.... last time i checked duane had a stock with over 600whp... i do not know if he switched when he went to 800+whp
joe
Supracentral
10
Stock flywheel is good for just about anything you can throw at it.
It's the rotating mass that most people are trying to eliminate. It gets your RPM's up faster which means you can get into boost quicker.
However, with that lack of mass, you loose momentum, the motor is quicker to "spin down" and it's a bit harder to drive in heavy traffic.
Everything in performance modification is a trade off.
Lightweight aluminum flywheels don't have enough mass to disipate the heat from a high performance clutch, and have a nasty tendancy to weld the clutch disk to the flywheel...
I'm running stock, and will continue to do so. If I cna find a good lightweight steel flywheel I might go with one of those. IIRC Duane is going with a new multi plate setup, which usually includes a new flywheel...we'll have to see
I'm mean to my clutches...and I have pics to prove it
ever seen a mirrored flywheel with cracks and hotspots? :evil:
not really my fault though...
why do you need a new one? if it's not cracked, it can usually be resurfaced for a small fee ($30 for mine, and they used a special mill to do it)
new one? dealer, as all the parts stores are on backorder (I just checked a week ago)
get pics and tell us how it feels...
I think I'll be using a multiplate if I get up to 500HP, but I hear they're grabby...
Dec 3, 2003
6,653
Canada
I will do a feedback thread when I install it.
The info I am getting is that it will be a bolt in clutch and will have a stock feel :)
Duane
