details:
88 supra turbo 7mgte w/ stock ct26 turbo w/ turbo blanket
this issue only happens sometimes, no constants (outside temperature/how long the cars been on/etc) noticeable.
when in boost (stock 7lbs) AND above 4000rpm it feels like i'm starting to lose power and begins to sputter. boost gauge shows it holding at a steady 7-8lbs. Other times it will scream to 6000rpms without an issue.
If I go into 5th gear, at like 2000rpms, i can go WOT and make a solild and steady 7-8lbs without issue upto 4000rpms without boost jumping or the engine making a peep, so i don't think its a boost leak.
Would too big a spark plug gap cause that? intermittently? I'm running ngk 4644 plugs w/ ngk wires; everything is plugged in securely. Originally it was gapped to .029, then I regapped to .025, and it seemed to get a little better, and from my research, i think that going to .022 may fix my problem.
I'm going to try to regap this week, I was just wondering if anyone had seen an issue like this before.
