Interior Fuse Box Replacement
gburfening
US
Does anyone know if it's possible to replace just the interior fuse box, or if it's just part of the wiring harness? The terminals where the blade fuses plug in have become loose over the years, and the fuses practically fall out and fail to maintain the connection.
Currently I've wrapped some tin foil around each fuse blade so that they're a bit thicker and fit in snugly. This has resolved the issues but obviously is not the ideal solution.
