for everyone who has done custom interior or redone it themselfs how did you reattach the new material on the door panels since it is glued on stock? is there any certain type of glue I should use or any tricks?? thanks
the inserts are only glued where u see that line..and then stapled on the back...not sure about carpeted area, im sure its glue.
On most i use contact cement, works pretty good with the materials i use.
