Interior differance
kamikazemkiii
1,219
North Carolina
Is their any difference between the interiors or the 89+ supras besides the steering wheel and colors? im doing a interior swap from a
89 to my 90, any help will be appreciated.
Thanks
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
for 89 to 90 there are no color differences, except I think they dropped tan for the interior, but I'm not sure...
interior wise, the switches to the left of the steering wheel changed, from the foglight switch, coin holder, rear defroster and coin holder, to foglight, defroster, dimmer switch and coin holder...
The panel housing them changed as well. The lower panel was also modified and used a foam backed, heaver two piece design, and will not swap in unless you get the dash bar and brackets to fit it as well. Other than the gauge cluster (which won't swap in), and the steering wheel, it's the same..
shaeff
Kurt is FTMFW x2!!!!
11
Around
Or go to the main forum (in this case- OFF TOPIC) and double click next to your thread title. It'll open in a text box that will allow you to change the title. AJAX FTW!
