does anyone konw the size of the stock intercooler inlet and outle?
M mista_sup New Member Nov 13, 2006 211 0 0 atlanta Dec 1, 2008 #1 does anyone konw the size of the stock intercooler inlet and outle?
M mista_sup New Member Nov 13, 2006 211 0 0 atlanta Dec 1, 2008 #3 does any one know of a quick replacement hose that i can use for my intercooler untill i go hard pipe.
IwantMKIII WVU MAEngineering Jun 12, 2007 2,477 0 0 Perkasie, PA Dec 1, 2008 #4 radiator hose if you can find one the right shape and just cut it up as needed
adampecush Regular Supramaniac May 11, 2006 2,118 3 38 Edmonton Dec 1, 2008 #5 plumbing rubber flex coupling has also been used in times of need....and it comes in many different sizes.
Yblegal91t it finally runs! Apr 22, 2006 331 0 16 C1 outer Dec 1, 2008 #6 put up a wanted ad in the parts for sale section. Im sure someone has the stock pipe you need.
G Guyana00 Droppin that JZ in soon! Apr 18, 2007 1,208 0 0 Brampton, ON Dec 1, 2008 #7 Yblegal91t;1192688 said: put up a wanted ad in the parts for sale section. Im sure someone has the stock pipe you need. Click to expand... This is probably a good idea.
M mista_sup New Member Nov 13, 2006 211 0 0 atlanta Dec 1, 2008 #8 thanks guys will check into it.. Guyana00;1192700 said: This is probably a good idea. Click to expand...
