Whats the best intercooler or intercooler kit? I was thinking of getting a mishimoto intercooler and have custom IC pipping. Any suggestions of different ones.
Ditto, fully expected it to be laggier but didn't work out that way and just made it harder to find traction in low gears..IndigoMKII;1751809 said:I would've figured with the larger pipes that the lag would be increased, not very much but a slight bit due to the increased volume to fill.
If you're chasing a genuine 600rwhp I'd go for 3" straight off.laxboy36;1751858 said:so what do you think is best for me, I have full 3'' exhaust and intake, should i get the mishimoto 2.5 IC and IC pipping or get 3'' IC with 2.5 IC pipping. but i am rebuilding a jdm 7m right now and wanting 600hp in it
hvyman;1752049 said:Running no name 31/12/3 with 2.5 pipes and almost no lag on the stock 1j twins. Prolly switch to a 2.75 on the tb side later on.
Logic tells me the bigger pipe would go on the Hot side of the IC, smaller on the cold side due to the cooler air being denser but having said that I always went equal size for ease of material ordering and one size clamps and couplers.suprarx7nut;1752066 said:Out of curiosity, why would you switch to a larger diameter AFTER the cooler?
Here's my thought process: The cooler air requires less volume, therefore smaller piping. Larger piping will only slow the air down before it gets to the throttle body/intake where you would really want it flowing fastest. Although I guess on the flip-side on that coin, the larger piping means you will have more "cool" air ready when you suddenly stomp on it? :dunno:
My logic might be ass-backwards, so let me know what your thoughts are.![]()
Personally I'd just go 3" straight off and do it once/properly, it might be a little laggy on the Gumby engine but who cares it's a Gumby enginelaxboy36;1752068 said:so with the stuff i have done to the car now should i just get the 3'' core from misihimoto and have 2.75'' IC pipping and when my rebuild goes in get 3'' pipping?
