:1zhelp: I am installing a FMIC and I want to know what is best, 2.5" pipes or go ahead with 3" pipes? :1zhelp:
do you think 3" piping could be a psi loss problem having 400-hp??born2drv said:most people that i've seen go with 2.5". mine is 2.5".
3" would be better of course, but probably only for 600+hp
hey thanks to all!!! My intercooler has 3' inlet/outlet but thats because I got a great deal on it!!! So I will stick to the 2.5 piping and use a reducer for the inlet/outlet for now!!:naughty:jdub said:Ok...what we're really concerned about here is flow. Think of it like this; psi is rate, pipe diameter is volume. Inceasing either will increase flow...how much (and how efficient) depends on the turbo you're using. In piping, the most restrictive section will determine the flow for a given psi.
jmcboost is correct...matching the piping will provide the least restriction for a given psi. That also means the intake/output of the intercooler...if you're gonna use 2.5" piping, the intercooler needs to have 2.5" intake/output. In our cars, it's usually the throttle body (assuming stock) that's most restrictive...it's 2 3/8" (60mm) in diameter on the side where it bolts up to the intake manifold. That's close enough to use 2.5" piping.
