Intercooler makeover
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
I've got the small hks front mount, but its in horrible condition. Bent fins, dented on the bottom of the outer core, probably dirty inside. If I take it into a radiator shop, can they fix all these issues. I'll call, but I just though I'd get some info on here. Its also painted white, will that aerosol aircraft paint remover take this paint off and return it to the polished aluminum look? .........and......... since the inlet/outlet setup is different than stock, does anyone know what kind of bends are needed for a hardpipe setup?
SMP142
BOHICA
Jan 5, 2006
367
Tacoma, WA.
do you know it works? i would have it pressure tested before you spend money doing anything. if it doesnt hold pressure then you might as well trash it and get a good one.
