Integration Relay
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Well, my interior lights and my key light in the interior doesnt work. So after a little searching on the internet I think the problem is I have a bad integration relay.. I found the light blue fuse box behind the driverside kickpanel, but cant seem to find a way to get behind it, or even see the integration relay...
How can I get access to the integration relay...
shaeff
Kurt is FTMFW x2!!!!
10
Around
try checking the bulb in the keyring, and the ground (the rivets) for the interior lights, first.
-shaeff
shaeff
10
Around
the ones near the rear view mirror? they're INSIDE the lighting unit. pull it apart, and you'll see what i mean. there are some cheesy rivets in there that tend to loosen up, thus causing the ground to be bad. you should be able to see when you pull it apart.
by the way, to pull it apart, grab it near where the mirror goes in, and pull toward you. it'll pop off.
-shaeff
