intake's for the n.a?
chris717
417
walnut creek, ca
I just wanted to know all the possible intakes that would fit my n.a?
for example- civic, prelude,accord..etc. i don't know the years???
would this fit my car....
Projectmk3
1988 hard top N\A
Jun 20, 2007
Ontario
92-95 civic, jus cut about an inch off the long side, youll need couplers 2
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Probably, but you're going to need an adapter to mount that filter to the stock AFM. In my MAFT Pro writeup I listed the E-Bay description (it says the model and years) for the pipes I ordered. The vacuum port for the power steering is in a MUCH better location. With that one you're going to need a much longer hose for the power steering vacuum hose.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
yup, it'll fit after cutting a little bit off..
I personally had the HKS SMP filter/adapter already, and it fit like a glove (filter's really shallow compared to others and everything fit tight, but I didn't have to cut anything). Just used 2 couplers and it came with a vacuum hose I just connected with my stock powersteering hose, and plugged up the 2nd nipple it came with...
not bad for $15, in my opinion...
chris717
417
walnut creek, ca
ive been asking people if they could post some pics of the power steering pressure hose ... can anyone do that for me?
underneath the car and from the engine bay.....
my hose hits the ground
CRE
Oct 24, 2005
3,485
Denver, CO
Sorry, I forgot to look at mine. But mine shouldn't hit the ground since i've got my engine undercover in place. ;)
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I wish i had an undercover...
*edit, what about the K&N kit? Do you mean a full intake set-up replacing the accordion pipe and everything?
s383mmber1
3,614
Somers New York
Come on guys, common sense is needed here.
If you want to replace the black pipe on your intake system, find one that looks like it fits it! Not rocket science!
And dont jsut cut random lines....
Some of you guys need :1zhelp:
cuel
1,536
Baytown, Texas
lol. Chris, you probably routed the hose wrong, and didn't put it back in its clamps. Sometimes zip ties work wonders.
As far as cold air kits, I just redid mine. Used some 3" alum. inter cooler piping, some silicone couplers, and cut it to fit how I wanted it(don't butt the tubes right up to each other in the couplers, leave a little space so they don't rub). Drilled a hole, put a grommet in the tube, and put a little vacuum nipple in for the line from the p.s. You could do the same with some misc. 3" exhaust bends. s383 is right, this isn't by any means difficult.
CRE
Oct 24, 2005
3,485
Denver, CO
You show me yours, I'll show you mine. :naughty:
It seems that at this moment no one has a pic. Post a picture of yours and the hose that's causing trouble and we'll see if we can't figure out the problem.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the high power line or the cooler line? honestly not much to either check the tsrm it has a good guide
cuel
1,536
Baytown, Texas
Here's 2 pics of how this c.a.i. turned out.
I had a box I made that kept the filter in the engine bay, but I wasn't happy with how it looked or performed. This was easier, for now.
I woulda got some pics of the p.s. hose, but I'm not at the shop, so I can't get under there easily.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
my friend had a random intake from a random honda in his garage, it fit perfect. end of story. lol
