intake
doom26464
Research...research
Saskatoon SK, Canada
I'm just curious but I happen to have a K&N drop in filter along with SOGI Poor man's K&N fpik mod where u like cut half the intake box up for better flow. Now would it be a better idea to go with the acutal full K&N FPIK. would I c a better increases in performance??? also has anyone ever tried any of these cheap 3" intakes off ebay like theses:
http://cgi.ebay.com/ebaymotors/3-AI...ewItemQQcategoryZ33659QQitemZ8011005460QQrdZ1
http://cgi.ebay.com/ebaymotors/91-9...ewItemQQcategoryZ33659QQitemZ8011483853QQrdZ1
would they work even better then my drop in K&N??
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Just make sure you plumb in air from out front, and not hot air from under the hood. Hot under hood air will drop you approx 5 hp. I ducted air from the front grill area to the K&N, and made a box around it to seal out underhood air.
I felt the increase in power after the box was done.
s383mmber1
3,614
Somers New York
The "sogi" mod works a little, but dish out the extra cash and go for the k&n FIPK, itll be worth it in the long run. i wouldn't suggest that you go with one of those 50 cents ones either, they are made out of practically computer paper! <<sarcasm..my friend has one on his camry and its pure CRAP
CSquared
Atlanta, GA
spend the extra money and buy the apexi, k&N, or blitz filter. Price may seem a little high but most of them can be cleaned and dont have to be replaced down the road.
gixxer750
2jzget comingsoon!
Mississippi
I would buy one of those ten dollar AFM adapters, go to advance auto and get a K&N cone filter, put it on....then you have spent 70 bucks on an intake instead of $120 for the K&N FIPK
mkiii222
Troy, MI
Nobody mentioned it, but I'm happy with the HKS SMF intake. Sure it's a foam type filter that can't be washed, but replacing the element costs the same(if not a little less) than cleaning/reoiling a K&N.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Don't forget re-oiling your pan too... using that filter.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
i had the blitz on my car, and i loved it. plus its stainless steel mesh so just rinse, dry, and slap it back on when it comes time to clean.
IHI-RHC7
"The Boss"
Oregon
The HKS doesn't filter, though. It looks nice, but it doesn't catch anything. and also, have you seen the surface area of the Apex-i? It's Tiny!
Go with FIPK, or the $10 adapter and a K$N from your local auto parts store.
Cold air is better, so open the snorkel hole, and build a heat shroud to keep engine air out. Just my 2 psi...
hot dayam mk3
149
i use a hks smf and its not the standard element filter... im using the racing element which is even worse but hey more open and less oil.... never had a problem with my afm for two years. just change element filters with oil change since it only cost $15
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
thats kind of scary. i thought the SMF was bad enough but a filter thats worse would seriously make me a little concerned no matter how cheap it was
oh, and listen to jake, cold air = good, it makes the turbo and motor happy.
mkIIIman089
Ohio
You should just get the Apexi. No oil, excelent power gain, and according to that one test it has pretty good filtering quality as well.
