intake manifolf
s7mgte
136
ny
when i start my car it idles pretty bad and its definatly a vacuum leak because i sprayed starter fluid around the manifold while it was idling and the idling smoothed out and jumped up. the thing is.. all the lines look perfect and im thinking maybe the bolts on the manifold it self are loose because my turbo is making boost also and whatnot and blowing off but the boost isnt making it into the motor.. feels like its not goin anywhere when u step on it at like 3k.but ull hear it whislting and blow off.. whats the easiest way to tighten these bolts.. they look impossible to get to
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
Most are pretty easy to get to with just a 6" extention and a socket, the one in the very far back is easier to use a longer extention and a swivel. You should just take the whole assembly off and seal it up with new gaskets, it's $8 for both upper and lower.
