Intake "Idea"
Ma70.Ent
1,871
NJ
If the stock Throttlebody is so restrictive, why do people bother upgrading their intakes, or changing out their filters? Is it just to get a new filter to keep things clean, or do they actually think it will help performance (or will it really help performance)? Just wondering.
s383mmber1
3,614
Somers New York
Why do people put cat-back exhaust on there car, and not a whole thing?
Same type of question here, and IMO people arnt looking for wicked performance out of a simple mod.
Its been dyno'ed that on NA's you DO get X hp from an intake system. Is it worth it? Idk, but it would certainly be better with a larger throttle body, and ported manifold...
Edit: Drunk post
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
a peice of 3 inch diameter 12 inch long tube to get rid of that intake resonator is like what 10-20 bucks? thats what ima do. CAI prolly makes better power but i live in florida and it rains like crazy everyday for like 2-3 months. so who knows if a CAI would be safe on my car.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
As I recall a member on here had the 7M's set up analyzed for flow rates.
The filter made a small difference, but the AIRBOX was much more restrictive. So by getting a FIPK from K&N or the Apexi' cone filter or the like, you remove the stock airbox and its restrictive properties.
As for the catback, is the stock muffler not restrictive? I would wager that it is. While I totally agree with s383mm about the exhaust being MUCH better when replaced as a whole, I would think you would see at least a small gain with just a catback that included a better flowing muffler.
Not to mention a better sound in most cases.
Once I figure out exactly how to do a new exhaust with my cali set-up or get rid of the cali set-up, I'll hopefully get new piping from the block back. If i get lazy and cheap, it may have to just be a catback.
My .02
cuel
1,536
Baytown, Texas
Iirc, the turbo and n/a throttle bodies are the same diameter. On the turbo model it might make a difference, but on the n/a I wouldn't sweat it. What I would do is try to make a CAI that is as short as possible. Thought about putting it in the fender behind the tire, to make a straight, short, cai. Just haven't figured out how to vent the outside of the fender correctly so that the filter wouldn't be getting a lot of road mist when it's raining. There's enough room in there to do it, and use a decent sized filter as well, but it would require moving a brace. Would have to move the afm, and extend the harness, or just go MaftPro. That would be the other restriction I'd solve before the t.b., the stock afm.
