instructions for replacing the HG
chandley
mkIII owner
Apr 27, 2006
SoCal
I'm replacing the stock headgasket with a new metal one and I need instructions on how to do it. I know you have to torque down the studs in a certain way to a certain ft/lb.
so if anyone knows exactly what to do that would be awesome.
chandley
mkIII owner
Apr 27, 2006
SoCal
Thank you very much. and i used the search, but just came up with a bunch of "do you think I have a BHG" threads So I just gave up and asked for myself. again, thank you for the links.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
No problem, I agree there are too many BHG threads here...:cry:
Take your time, bag and label every thing(nuts and bolts), Take pics before hand, ask questions and don't take short cuts as they will bite you..
Good luck.. :)
Edit: As for torque specs, I would advise going to at least 80ft/lbs with molly lube. (this is debatable by many here) some say higher depending on your boost plans.. It should say what they recommend in your hardware specs if you use ARP's.
Also, different metal gaskets require special RA surfaces so tell us what gasket your using..
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes.
chandley
mkIII owner
Apr 27, 2006
SoCal
AWESOME! diagrams are always helpful.
what all do I HAVE to take off? just, everything above the head?
any special order for dismantle???
Sorry for so many questions, I just REALLY dont want to fuck up.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
No, Mine is the torque down pattern that he asked for. The one you have must be the bolt loosening pattern.. page EM-39
