oneandgone said:JDM MKIV's use 440 cc injectors. All MKIV's use side feed injectors. Side feeds WILL NOT work on the 7M. BTW...side feeds are teh suck.
gixxer750 said:Wrong answer. I have a friend who has a 1993.5 mk4 non turbo automatic. He has a 2j-ge engine, and his car uses top feed 440 cc injectors, that happen to have the same part number as my stock injectors. The afm housing is also the same, although the electronics are not.
Idealsupra said:MK4 TT injectors WILL NOT WORK.....PERIOD.
Idealsupra said:ummm no RIGHT answer...considering we are talking about mkiv TT 550cc injectors... not NA MK4 injectors...
Jeff Lange said:Unless you did up a custom fuel rail.
gixxer750 said:no, this is the post I was replying to. Therefore, I am correct.
