installing a bov
shima1469
5
fresno
i have a 87 n i need to know wat to get to put a bov on my car..... do i need to get the metal piping that goes to my intake or could i still b able to install a bov with the plastic instead of metal ??? so yea wat do i need to buy?
robbo185
693
Chicago
most online stores sell kits that will either:
A) use the stock locations
B) Comes with a pipe with bov flange welded on that replaces a piece of stock IC pipe where you just then block off the original BOV locations.
What Bov were you looking to buy
p.s. your car comes with a bypass valve if you didnt know (not calling you dumb but some people dont realize this)
shima1469
5
fresno
well i dont really know about bov's n shit like that so yea.... i was gonna get a hks or greddy bov... but i wasnt sure if i need the full kit.. or if i can just get the pipe wit the flange on it n just put that on or wat...
Dirgle
Conjurer of Boost
Pauma Valley, CA
It should also be noted that our cars don't take real kindly to BOVs, unless adjusted correctly (and some times this can be a real pain to hit the right spot) the car will bog down and possibly stall.
You say you don't know much about BOV's, so I would recommend doing some research as to there affect on our cars before you just go out and buy one. There is a good deal of information located in these forums on the topic, with a little searching you can find them.
It should also be noted that the recirculation valve that comes on our cars can hold a fair amount of boost, and work really well. So there is really no reason to replace the recirculation vale with an aftermarket BOV, except for the sound it makes, but you sacrifice a little bit of performance for that sound.
So unless you have large amounts of boost to hold or one of the ECU piggy backs that compensate for the overly rich situation that an aftermarket BOV creates, there is no real reason to get rid of the stock unit.
