installation of the msd ignition 6200
supra concept
26
france
hello I have to buy a msd ignition 6200 and I do not know how to connect:icon_conf . can you explain me ,send me wiring to install :1zhelp: .thank you very much
bigaaron
4,692
Pomona, CA
www.driftmotion.com
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Big waste of time and money trying to upgrade the 7m-gte's ignition, it's pretty good as it is ;). Unless you're trying to lay down 500+ HP I wouldn't bother with it. If you still want to upgrade, check out the threads on 1JZ and 2JZ coil pak conversions ;).
supra concept
26
france
tank you very much for your help. I will take the hks dli for the installation (damage for the msd 6200):icon_conf .yes starscream5000 I have must 500hp .
zack_odom
Boring Man.
Nov 19, 2006
17
Seattle
MSD doesn't do anything to the coils....
MSD stands for Multiple Spark Discharge...I will do this to my next Supra,
MSD means that where your spark plug usually fires one time it now can fire multiple times per revolution of the engine....it increases not only power, but the amount of gas burned per firing of the plug...That can also reduce emissions, seeing as how more of the atomized fuel is being burned.
any way that is just my two cents...:biglaugh:
