Inspection, should I pass?
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
I'm gonna be getting a new inspection sticker, and wanted to know if I should pass inspection. I have a JDM 7M-GE with around 41,XXX miles, converted to US spec. New NGK plugs/wires, and I have a stock exhaust with a glasspack resonator, which is the only thing I'm worried about, because I believe it has a leak, due to the fact that it drones at 2500 RPM or higher when the car is cold, or that could be the actual glasspack. You guys think I'll pass ok?
-Matt
lagged
1991 1JZ
new rochelle
if your o2 sensor is in good shape (and hooked up properly!) you should pass with no problem.
you converted it to US spec? what does that mean? you installed the EGR? FWIW when my car was stock i passed with my JDM 7m with no egr well below the limits.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Oh, I met that I installed the US intake manifolds and exhaust manifolds, and switched out the JDM oil pan with my old one.
-Matt
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
If you are talking a smog inspection, are they run by the state?? or private??
Private...try to find one that will give you a free re-test if you fail. The print out will us help figure your problem out if you do fail.:biglaugh:
lagged
1991 1JZ
new rochelle
-Matt
ack! why in would you go through all that trouble? they are the same ....
