Someone gave me injectors out of a 91/turbo. I know that they are a bigger cc but will they fit in my 89/ n/a?
ill Z said:Correct me if I'm wrong, but doesn't larger injectors not have anything to do with pushing more fuel? You would need other supporting mods to get there, 440cc's is just refering to the maximum amount of fuel you can acheive from them?
gnarkill87 said:yes they would push more fuel cause your putting larger injectors in but the fuel pressure is staying the same, so more fuel, if you have a fpr and turn down your pressure you can run larger injectors with the same amount of fuel as stock though theres no point in doing that cause the fuel doesnt adamise as well.
7M-fanatic said:Yes, why ??
If you go to an adjustable fuel pressure regulator, why change the injectors?
Just turn the pressure up on the stock injectors.
Not only will they flow more, but you end up getting a better spray pattern out of them.
That is if you actually need more fuel, and that is doubtful......
