Injectors not shooting fuel... HELP!
beerxd
51
bkny
i know the the fuel pump is working and its getting to the fuel rail but the motor doesnt turn on im thinking it has to be something with the injectors.. i have checked the timing and spark plugs and i am getting spark... i dont have a check light to see if the injectors are getting power.... what may it be?
peste noire
266
los angeles,CA
maybe theyre clogged.
spray some carburator cleaner in to your throtle bodyand try to start it right away to see if its a fuel issue.
also check your EFI fuse.
Any codes?
Highly doubt all 6 injectors are clogged. Most likely a wiring or sensor issue.
What was last done to the car.
Any codes?
beerxd
51
bkny
im sorry guys i been busy with the start of this semester.... i have just swapped a 90 gte motor into a 89+ na shell i repinnd the B1 plug.. the motor cranks and but does fully start it shuts off...
peste i have sparyed starter fluid into the TB and it helped but shut off anyway
