okay i got the fuel pump working now, there is spark, everything else seems to be working but the injectors are not working! What could be wrong? Since the injectors are not firing could it be the harness wire that i wired wrong somewhere? no codes are thrown related to the injectors, just tps code, oxygen sensor code, turbo pressure code, coolant temp signal code, and i think thats it. can anyone give me anyadvice before i decide to redo the harness wire?
