Injector question
josh930
247
NY
I have a set of RC550's from my 7MGTE and was wondering if they work with the 1jz with the 7MGTE resitor? I searched injectors and saw a pic of the fuel rail but nothing of my question. Now it seems that they wouldnt fit because of the clips and the injectors being inside the rail. Could someone please clarify this. Thanks, josh
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
they're completely different by design. The 7M uses top-feed injectors (injectors sit below the rail), the 1/2JZ use side-feed (injectors sit inside the rail). You can get an aftermarket fuel rail and use them if you would like, or you can sell them to some 7M owner, and get a set of USDM 2JZ injectors.
