Injector Question
Apr 4, 2005
55
Milwaukee
So, I am adding a turbo onto my N/A for the 1/2NA-T. This means I will be keeping all of my electronics and do tuning by a Wideband and a SAFC.
Now I know I have to get Turbo 440 CC injectors and I have heard that they are low impeadence(sp?). My 90 N/A has high impeadence injectors on it now.
Is there anything else that I will need to use 440's? Or should these plug and play?
Apr 4, 2005
55
Milwaukee
Sorry lagged im looking at some $40 injectors.
Does the resistor pack have to come off of the turbo model. I have a 86.5 parts car which should have the resitor pack. Will that work or will I need the one off the turbo model?
thesupraman
Smirker
May 15, 2005
129
Frenchtown, NJ
Jeff Lange said:
N/A and Turbo resistor packs are the same. :)
Unless your NA is equipped with high impedance injectors. I believe I read somewhere that 88? (not sure of the cutoff year exactly) and older and NA's came with low impedance injectors and would have a resistor pack. So supramatt, if you have one it will work fine, if not you will need to get one from an na or turbo.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Well, since the 89+ Supras had high impedence injectors, they wouldn't even have a resistor pack, meaning that all the resistor packs (N/A and Turbo) are the same. :)
