Injector low impedance resistor wiring
BigSupe
97
England
Has anyone got any info or pics on how to wire the 7m injector resistor pack for my 1j, I'm trying to fit some 550cc:1zhelp:
aphxero
787
Seattle, WA
Its pretty easy.
theres voltage in, a, b, and c. Voltage just grab from regular injector power. Blk/orn on 1j. Then you can power the inj in pairs in what ever order.
I'll take pics of mine if I get a sec.
BigSupe
97
England
thanks that would be great
Correct me if I'm wrong but the way I believe the injectors to work is a seperate +12v and -12v to each injector from the ecu, so in my mind the resistor for the 7m has six wires on the outlet and one main inlet wire, the bit I'm unsure on is that you twist the six -12v wires together and connect to the main inlet wire then you join the six wires from the resistor to the six wires that have been cut from the injectors?
crazysupra2JZ
740
Georgia
there are only 4 wires coming out of the resistor pack. BO, R, B, Y
BO goes to that big 24 pin (i don't know exactly how many pins) plug under the dash. the other wires goes to the injectors, one wire per two injectors
