Nick M said:Open loop? Open loop means the computer is not responding to its own control, just the look up tables from the sensor readings. Closed loop is the scale back. The oxygen sensor is monitored, and air fuel adjustments are made from it.
Open loop is when fuel is "dumped". You can't be at wide open throttle (WOT) and be in closed loop.
The TCCS engineers decided it based on VE of the engine, and injector size.inline6 said:Exactly, so how does the computer decide what percentage the inj. duty cycle should be at WOT.
Under what circumstances? The ECU fuel trim is going richer trying to correct what it sees as lean. You have a turbo 7MGE? Stock injectors are about 320cc GE or 440cc GTEI'm not adding any fuel so why does my car go to 94% when you guys say 85% is the safe limit.
Fuel trim is an attempt to compensate for driving style and wear and tear. The tables can and do change.If it is strictly based on the preset tables does this mean toyota wrote a table from the factory to run injectors at maximum DC in open loop?
Its a 1jz on the stock injectors 370cc. I guess I'm confused about the fuel tables because I thought it gets no feedback from the o2 sensor in open loop so I didn't know it could "see it as lean".Nick M said:Under what circumstances? The ECU fuel trim is going richer trying to correct what it sees as lean. You have a turbo 7MGE? Stock injectors are about 320cc GE or 440cc GTE
Nick M said:You are posting in the wrong section. The harder or softer you drive, the more the table will change. Oxygen sensor feedback is an emission function that keeps the catalytic converter in its optimum range.
inline6 said:Exactly, so how does the computer decide what percentage the inj. duty cycle should be at WOT. I'm not adding any fuel so why does my car go to 94% when you guys say 85% is the safe limit.
