Infuriating Brake Job
wolfman_matt
Stocker
May 8, 2008
Apex, NC
Any tips on getting the piston compressed. I have always had no problem just using a C-clamp to squeeze it but it is very stuck this time. Could it be seized? Can the piston come out too far and hang up? I'm able to bleed fluid so I'm assuming the brake lines are not plugged (the brakes worked fine prior to trying to replace the pads). I haven't taken the caliper off before but maybe that would help? Thanks for any suggestions. Matt
Kangae
Buzzin' Half Dozen
Sep 13, 2007
249
Utica, New York
I normally use a c-clamp type thing for mine and that works, I know some people use channel locks but I'm not a big fan. With the C-clamp, I can't offer much advice, just make sure its centered.
tissimo
Stock is boring :(
Melbourne, FL
If its hard to push the piston in with a C Clamp your pistons are sticking. I'd start looking into rebuilding your or getting replacements.
RiyadYar
384
NY
c-clamp never failed for me but like previously stated if your having that much trouble maybe its time to get some new ones
wolfman_matt
Stocker
May 8, 2008
Apex, NC
Thanks for the suggestions guys...I had the BMC lid off and was able to bleed out the bleeder valve. But still no luck with the piston.
Final decided to disconnect the brake line and that allowed me to get the piston to compress. I then bled out the air and checked to make sure the piston moved when the brake pedal was compressed and put it back together.
More headache than planned but I survived and learned a few new things.
Kckazdude;1410971 said:
If you arent kinking your rubber line when trying to compress the clamp then you need to rebuild/replace the caliper.
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
sounds like there's blockage/corrosion in the hydraulic system either inside the caliper itself (common) or between the caliper and the BMC (rare)
does your car have ABS? if so that might have been the problem.
rayall01
901
Westfield, ma
Yeah, just because you can bleed it, doesn't mean the hose isn't bad. The hose can be blocked in one direction and work OK in the other. Replace your hoses. It's would give you an excuse to upgrade to steel braided.
rayall01
901
Westfield, ma
gaboonviper85;1411266 said:
remove caliper....have a friend slowly press the break pedal to break the piston free....then try to compress it again with the c clamp.
Gaboon, he got the piston free, when he removed the hose.
