where is the inertia switch located on and 91 toyota supra... inertia switch used for collision purpose. once in a bad collision it shuts off the fuel and you will have to reset it.. if you didnt know... any1 know wheres its location is...
The fuel pump switch in the AFM would disengage without air intake, which would cut power to the 'circuit opening relay', and power to the pump would cease.
The ECU controls this relay on turbo cars.:icon_bigg
