inconsistant knock top motor
90targaturbo
4
dayton Ohio
i have a loud inconsistant knock coming from the top of the block i dont have a loss in compression and it is coming from cylinders 1 and 2 and the is hearing it from a stethiscope i am about to pull the head and look at it but before i do is there anything else i might be able to check all imput would be appreciated
thanks Jack
radiod
1,342
Abbotsford, BC
Is it when it's hot or cold or doesn't matter? If it's on cold start you could be hearing piston slap. Check and make sure all bolts are torqued to spec as always.
