Hello everyone.
I'm Matthew from Southern California. I have been a member on Supramania and SocalSupras for some time now. Although I don't post often, I do receive the lion's share of Supra information from Supramania.
Being that I've owned my car for 4 years and daily"ed" it, I've already worked on my car. So this isn't a total rebuild thread. Maybe a diary:sarcasm:. Here is the car:
I've have been lucky enough to have owned only 1 supra, my 89. I have been through most Supra related catastrophes. I've have been through one motor, which was lost to BHG. My fault though.
My Supra has a built Driftmotion 7M-GTE, 57-trim, and full-exhaust. Bilstein+Rs*R suspension, F&M&R&UR and Master cylinder braces. Also a Blitz boost controller and Koyo Radiator. Also other things here and there.
The reason why I started this thread was my Supra most definitely has a motor issue; crankwalk.
Overall goal 350Rwhp.
While the car is down, I want to:
Re-coat the undercarriage
Stainless steel brake-lines
Full-flow oil cooling system
Power Steering cooler
Battery Relocation
Synchronic BOV
IC piping and Intercooler
Driftmotion Oil line
BIC Engine Brace
Prosport Gauges
Shim oil pump
Lower Front Ball joints
Fuel pump, injectors, DM SS lines, SAFC, and Lipp AFM housing.
Bushing kit(if it's made)
Then a tune.
Here and there, I want to make a few things. First, a stealthy way to house 4 gauges and a SAFC. Second, a quarter window delete, I want to smooth the interior a bit. I can't see out of the windows anyhow.
BTW The Supra has been given a break it is completely a hobby car. It was replaced with my Z.
Any input along the way or questions or inspiration is welcomed.
Engine will be coming out on Sat/23. Then it's time to find a machinist.
Matt-
Battery Relocation
Synchronic BOV
BIC Engine Brace
Prosport Gauges
Shim oil pump
Then a tune.
Matt-
