impossible compression reading
Dire McCain
23
Florida
What? Doing a compression check with my trusty Sears compression tester and I am now getting a reading of 240 lbs/sq.in. on number 6 cylinder...isn't that just not possible? Should be closer to 156...
Is the tester just not working? Has to be...engine runs good...no missing...good power.
I was checking for the blown HG and keep getting inconcistent/impossible readings with the tester.
1988 5 speed, non turbo...
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
try to borrow a tester from one of the auto parts stores and see if it repeats. if you're getting good readings on the rest, i'd say its correct.
