importain note to polpe looking at lex thottle body
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i herd some where on the forums that the lex thottle body fit's ours car's
well it does not bolt up ): but it does use the same tps and it is bigger 70mm
stock is 50mm
so i am thinking this will be good upgrade for my or any lex afm people
i did think of the getting the q45 but really the head and such will yeild some air flow and it's more exp liek 200 buck's form frined of mine this lex one cost me 20 bucks
NashMan
Aug 5, 2005
4,940
17
Victoria BC
jza70mk3 said:
does the q45 bolt up
umm yae if you use duck tape
but no it far form bolting on the only tb that will bolt up is the turbo a throttle body bad there really no point since it's only 5mm bigger then stock
stock 60mm
trubo a 65mm
lex 70mm
q45 80mm or 90mm need good flowing head for these bad boy's
the good thing about the lex is our tps swap right over
NashMan
Aug 5, 2005
4,940
17
Victoria BC
no it's not really bolt on thing it just bigger yota tb that use's the same tps and butter fly that moves the right way stock is 60 turbo a is 65 lex is 70 and the q45 is a 80mm
