I'm sick of stupid worm clamps.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Where can i pick up some T-bolt clamps for cheap? Are there any autoparts stores that carry them, or are they only available online? I'm not looking for any irregular sizes, just a couple 3" and a ton of 2 1/2" clamps. whatcha say?
shaeff
Kurt is FTMFW x2!!!!
11
Around
doesnt hightempsilicone here on the forums carry T-bolt clamps? ;) have a look in the vendor's section.
-shaeff
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Not bad prices.. thanks shaeff! I'd still choose locally rather than ordering something.. I'm going on a boostleak-hunting frenzy. I want it to stop now.
Btw whats the diameter of the factory hose comming off the snail?
koulee
497
You guys have a count of the number and size of t-bolt clamps in order to get everything secure?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Don't forget when ordering T-bolt clamps, to always go .25"+ the ID of what you're clamping.
(Depending of the wall thickness... HTS has HUGE THICK walls, so I dunno what T-bolt to use with them.)
Or else they won't fit.
See if you can find a bit Hydraulic Hose Supplier/repairer in your area they stock them and usually not that expensive as they don't have the Ricer Markup that almost all AutoParts stores charge these days!
