I'm no wiring expert at all, so I'm looking for advice.....
rakkasan
Currahee!!
Fort Campbell, KY
for one reason or another, the provisions within the engine wiring harness for the hydrofan ECU was removed. I am a huge fan of the hydrofan, so I want to retain it (fully functional).
I have wired the solenoid in to a switched power source with a diode in line so it will partially open the solenoid. This is working for the time being, but I still want the ECU to control the fan so I wont have to worry about the car overheating.
With the preface above, I'm looking to create a separate hydrofan harness, attaching to all the correct sensors, so I can regain all the functionality of the hydrofan. Is there a TEWD that shows where the hydrofan ECU draws all of its signals from? If there is, it shouldn't be too hard to create a harness for, no?
Any help will be GREATLY appreciated
JonoTurbo
Going for broke
CT
I'm not sure if this will work, but I have attempted to attach the hydrofan wiring diagram. There is a temperature sensor in the radiator you will need in addition the the computer and pump. The diagram also labels something as a distributor, which must be a bad translation so you will have to figure out what they actually mean.
View attachment 1JZFanComp.pdf
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
I don't understand how a diode would block *some* voltage allowing the solenoid to partially open? Diodes either allow all or block all voltage/current, depending how they're oriented. Unless you meant resistor??
rakkasan
Currahee!!
Fort Campbell, KY
I meant resistor, sorry about that
