I'm going to rebuild my engine
Sonex2000
172
I want to rebuild my engine. If there's a mechanic in the NY area that wants to do it......PM me.
I got the MHG already.
What else should I get?
C
cnewingham
Guest
I can get oil pumps new for $160. They are made by ITM but the funny part is that they drill out the toyota casting which means that it is the same as you get from the dealer without the toyota lettering. I just bought another one and you can definetly see the T.
wh0wants2know
55
seattle
absolutely new oil pump. That thing is a critical component on your car and if it has some miles on it, it's worth replacing. Get it NEW from TOYOTA, it's like 190 or something from champion but it's worth every penny. I would also replace the water pump. The only time I wouldn't replace those two things is when I know EXACTLY how many miles they have on them (because I installed them last) and it was less than 100,000.
lagged
1991 1JZ
new rochelle
you got PM. my friend will build it with all new parts, new oil pump, new water pump, new rotating assembly, all from toyota.
