guys I have an 89 i've been trying to get the bugs worked out of and it doesn't seem to want to run right, it's always running too rich under boost and running really hot on high rpm freeway driving without boost (EGT THAT IS) over 1500 degree at 80+mph just cruising, anyways I have complete fuel system with vpc and afc, I have try everything on my tuning, lower the fuel and rich the fuel settings and both and were not of help, it seems like the car is pulling timing in a way kinda like how it would if the knock sensor is bad or the engine light code is on for knock sensor, "BUT" IT DOESN'T PULL TIMING THAT BAD, I mean when boost hits at about 15psi or more the fuel doesn't get burn and all you see is black smoke from the tail pipe. This is a dumb problem and I can't seem to find it, if anyone might have ANY toughts of what it is please share it with me, I have changed EVERYTHING that I think it was and still, nothing. I'm lost here and been lost for the last year or so with this car, I just keep cracking ring lands on the pistons because I'm running so rich trying to test the car under full boost, and that's why I said, F it i'm going fully build so the pistons would hold a little more heat, SO.....any toughts guys?? Thanks for your time.
Steve
Steve
