Hey guys. First of all about a year ago I was having an ignition switch problem, I did some research and found the following write up:
http://www.supramania.com/forums/showthread.php?76403-Car-not-starting-randomly-READ-THIS-%2830-Amp-Starter-Relay-Mod%29
So I tried that and it worked perfectly. However the other day I go out to start the car and it just clicks. Now before I was hearing the click form the starter plunger, I no longer hear that. All i here is the fuel pump and a click that sounds like it is coming from behind the glove box. Is there some starter relay being there that could be going bad?
I replaced the relay that is in the mod just thinking that may have gone bad, but nothing.
Now if i take the wire that runs from the starter solenoid and touch it straight to the positive terminal it fires right up.
Any thoughts?
Any thoughts?
