ok, my starter works fine. the problem is that the only way I get it enough juice is through a terrible ghetto made at home starter switch that hooks directly to the battery. The car is manual and because of the switch I'm able to bypass the starting with the clutch depressed which I guess is cool but... eh time to go back to the ye old key method. So I've been reading the tsrm and apparently it's going to be one of three issues.
1) An open circuit, which I doubt because the way I currently have the power going to the starter would be fucked seeing how I have it spliced into the line directly before it hits the solenoid.
2) faulty ignition switch
3) faulty clutch start switch
4) fusible links... wtf? Ok with the tsrm I've been able to locate the ignition switch and the clutch start switch but where the heck are these "fusible links" that supposedly run from the battery TO the ignition switch/ clutch start switch.
On a side note, interestingly enough there have been times when I've actually been able to crank the car using the key ignition after running it for a while, as though it couldn't be the fusible links because wouldn't that just outright kill all possible key ignition? So my plan is to test what I know first, but if any of you could tell me where the fusible links are I would REALLY appreciate it
Thanks!
Thanks!
